TwinTurbo.NET: Nissan 300ZX forum - Does the oil smell like coolant?
Subject Does the oil smell like coolant?
Posted by Draker (Eugene, OR) on May 04, 2012 at 12:01 PM
  This message has been viewed 205 times.
In Reply To A little coolant in the PCV tubes posted by Dawei on May 04, 2012 at 11:44 AM
Message Or does it smell like gas? Because coolant often makes the oil look like a milkshake.
If you are running super rich and there has been injector work done, it's almost always a pinched oring. You will need to remove the injectors and replace the orings as needed and be sure you lube them up before you install them or you will be pulling the plenum again very soon. Best way is to install the injectors into the rail, pressure test them then install the rail so you know they aren't leaking.
By the way, if the car is still running rich, don't drive it.
