TwinTurbo.NET: Nissan 300ZX forum - The slave better not be dead.
Subject The slave better not be dead.
Posted by rojoloco (VA Beach) on May 04, 2012 at 9:11 AM
  This message has been viewed 192 times.
In Reply To I would thoroughly clean you slave of wetness, then posted by doug8867 on May 04, 2012 at 07:03 AM
Message I replaced it about 3 years ago (~3k-4k miles). I swapped out the slave line with the stainless steel braided line at the same time. If they are alreayd bad, it means I got bad parts so that seems like an unlikely cause. I should definitely check it out though. It certainly can't hurt. I have been looking under the car every day and I'm not seeing any oil puddles or stains directly below the slave so I think my guess of it coming from up above is probably correct.
Never Play Leapfrog With A Unicorn!!!
Do yourself a favor and just worry about your own car. I don't see what everyone is so worried about anyway. If someone else wants to perform a modification that you believe will destroy the value, cheapen the Z32 or whatever you can't sit on your hands about, wouldn't that make your tastefully-modified, white bread Z32 more rare and valuable? -- BradZ (FL) on December 23, 2007 at 12:19 PM
The unicorn gets its revenge... -- Scotts94z32 on September 19, 2006 at 11:12 AM
CLICK FOR DETAILS ABOUT BUYING A ZAMA POSTER!!!!
