TwinTurbo.NET: Nissan 300ZX forum - I've gotten conflicting info on the clutch booster.
Subject I've gotten conflicting info on the clutch booster.
Posted by rojoloco (VA Beach) on May 02, 2012 at 1:47 PM
In Reply To If you can't even shift the car into gear there would posted by doug8867 on May 01, 2012 at 09:00 PM
Message I've been told a bad booster would not cause this problem. As for a pedal adjustment, the pedal is way too soft so I'm not even sure there is a point in doing it.
I do have 2 questions:
1) If a pedal adjustment makes it to where I can shift, is it okay to drive it with a band-aid like this or will it only perpetuate the actual problem?
2) If the fluid level is not dropping, what is a sign of a bad clutch master cylinder?
Never Play Leapfrog With A Unicorn!!!
Do yourself a favor and just worry about your own car. I don't see what everyone is so worried about anyway. If someone else wants to perform a modification that you believe will destroy the value, cheapen the Z32 or whatever you can't sit on your hands about, wouldn't that make your tastefully-modified, white bread Z32 more rare and valuable? -- BradZ (FL) on December 23, 2007 at 12:19 PM
The unicorn gets its revenge... -- Scotts94z32 on September 19, 2006 at 11:12 AM
CLICK FOR DETAILS ABOUT BUYING A ZAMA POSTER!!!!
