TwinTurbo.NET: Nissan 300ZX forum - Check the MAF.
Subject Check the MAF.
Posted by MixManMash on May 01, 2012 at 7:44 PM
  This message has been viewed 329 times.
In Reply To Stumble at low rpm, kinda stumped...continued posted by Woody75 (Denver) on May 01, 2012 at 11:13 AM
Message The other thing I have noticed is that despite it appearing that sensors are reading correctly in data scan, corrosion or an intermittent break is enough to cause weird issues.
I had a weird stalling problem a few years back. All sensors were reading correctly. Even replaced the O2s. Later, I discovered the EFI harness had some resistance between the O2 connectors and the pins on the ECU connector. The harness had corrosion a good 25" from the O2 connector up. I cut and soldered some fresh wire and it solved the problem.
