TwinTurbo.NET: Nissan 300ZX forum - Maybe I just figured it out...
Subject Maybe I just figured it out...
Posted by beanz on April 30, 2012 at 7:13 PM
  This message has been viewed 132 times.
In Reply To Testing fuel pressure with FPR vacuum disconnected posted by beanz on April 30, 2012 at 06:53 PM
Message I was thinking that as you pass 0 psi and enter positive manifold pressure, the FPR keeps adjusting as manifold pressure increases.
In reality, is it that at 0 psi and over the FPR configuration is static, and that the fuel pump speed/fuel controller is at that point what keeps the pressure up where it should be? If that's the case then I guess "consistent at 51psi" means at 0 psi manifold pressure, but that the actual pressure increases as the fuel delivery system works harder under load?
Maybe?
Andy
