TwinTurbo.NET: Nissan 300ZX forum - TT Shock Actuator Delete
Subject TT Shock Actuator Delete
Posted by weezee on April 30, 2012 at 11:54 AM
  This message has been viewed 419 times.
Message I'm replacing my stock TT struts and springs this weekend with KYB's and will need to delete the electronic suspension components. I've searched around and can't seem to find anything that show's what steps need to be completed when removing the actuators permanently. If I just remove them and not put them back, will that cause any issues? I'm also removing the switch from the console, so the same question goes there too. I found a good write up on how to remove and replace the struts here ([ http://www.twinturbo.net/net/viewmsg.aspx?forum=technical&msg_id=941241 ]) but the images are missing. Anyone know if this was updated somewhere else?
Thanks!
“Gentlemen, you can’t fight in here! This is the War Room!" — Dr. Strangelove
