TwinTurbo.NET: Nissan 300ZX forum - Not a lot to it - install SB into the slave cylinder,
Subject Not a lot to it - install SB into the slave cylinder,
Posted by jzack on April 29, 2012 at 10:29 PM
  This message has been viewed 277 times.
In Reply To Do you have a write-up? (n/m) posted by rojoloco (VA Beach) on April 29, 2012 at 06:49 PM
Message don't fully tighten it, attached some clear hosing and put in a container. Fill the MC fluid reservoir and start pumping away -- monitor the clear hose for an absence of air bubbles - once done tighten the SB. Repeat same procedure for engine bay topside bleeder port using a 2nd SB valve....
SB is just a 1 way valve - let's fluid come out but keeps air from getting sucked back into the system....
