TwinTurbo.NET: Nissan 300ZX forum - mystery problem
Subject mystery problem
Posted by alpinekev on April 29, 2012 at 6:55 PM
  This message has been viewed 165 times.
Message I did an engine swap cause my NA motor spun a rod bearing I did the 120 k gaskit kit to it changed the oil pump and pick up and water pump changed turbos cause the jdm ones had too much play in them and changed the o rings on the injectors now here's the mystery I have everything back together but now it doesn't start I checked for spark I have that I checked my injectors to see if they were firing in sequence and they are but if i spray starter fluid into the Plenum it starts for a moment then dies I'm using denso spark plugs which I know are wrong but it should have started still I'm confused as to what it could be and i have no idea what else to do please help
