TwinTurbo.NET: Nissan 300ZX forum - Rough idle and small backfires
Subject Rough idle and small backfires
Posted by elisvk on April 28, 2012 at 10:44 PM
  This message has been viewed 797 times.
Message Hi. I have a 1990 300zx TT with 666cc injectors running 17psi jwt ecu and k&n intake.
I'm having a massive problem with the performance of my Z.
I have absolutely no problem starting it. It starts on the very first crank every time even when cold. When the car is hot theres a rough idle. It may drop down to 500 rpm and sound really lumpy. Then it can run on 800 rpm normally just fine.
The biggest problem is that when I accelerate past about 4500 rpm it just chokes and it sounds like a cylinder cuts out. This doesn't really happen in 1st gear but past 1st and it's like driving a 200whp car.
So far I've only changed the fuel filter and I definitely noticed a difference but that may just be cause the fuel filter had not been replaced for a long time.
Please help me troubleshoot this problem :)
Best regards from Iceland :p
