TwinTurbo.NET: Nissan 300ZX forum - Though not related to a plenum pull I would replace the >>>
Subject Though not related to a plenum pull I would replace the >>>
Posted by ZUL8TR on April 28, 2012 at 1:39 PM
  This message has been viewed 493 times.
In Reply To intake manifold maintenance posted by Jiro on April 27, 2012 at 01:46 AM
Message thermostat since you are replacing the coolant temp sensor. Proper temps need for the ECU for all sorts of things including fuel flow when cold or hot. Poor gas mileage has been due to a faulty theromstat. Stick with the standard OEM replacement that starts to open at 170 and fully open at 194. Check for proper operation of the new on the stove with a pot of water with thermostat suspended in water and a thermometer. The thermo opening specs are in the shop manual here
[ http://300zx-twinturbo.com/cgi-bin/manual.cgi?list=lc&dir=&config=&refresh=&direction=forward&scale=0&cycle=off&slide=15&design=default&total=15 ]
ZUL8TR in Orlando,FL
