TwinTurbo.NET: Nissan 300ZX forum - Re: Sounds like a wastegarte issue, that is the only reason
Subject Re: Sounds like a wastegarte issue, that is the only reason
Posted by Blurr on April 27, 2012 at 3:48 PM
  This message has been viewed 147 times.
In Reply To Sounds like a wastegarte issue, that is the only reason posted by MeatMan - 604Z.ca - on April 27, 2012 at 03:21 PM
Message Im going to tee in the lines tonight and use a blowgun with a gauge to test, Also check the fuel pressure and check for boost leaks.
its not overboosting, but jumping from low to high boost during misfire or backfire.When it does I notice on the AEM boost gauge the numbers fluctuate and the end result is the high boost.
