TwinTurbo.NET: Nissan 300ZX forum - By "no power" do you mean there is no voltage on either
Subject By "no power" do you mean there is no voltage on either
Posted by DVDBURN (MD) on April 26, 2012 at 8:08 PM
  This message has been viewed 139 times.
In Reply To Build Not starting! posted by dzero196 on April 26, 2012 at 07:08 PM
Message side of the injector pins? If not, check the fuses in the small fuse box in front of the battery. If you have voltage to the injectors but the injectors are not operating, check the power to the CAS (one wire should have battery voltage) and the signals from the CAS (5 volt pulses). If the ECU does not get the pulse signals from the CAS on pins 41 and 42 the coils and injectors will not operate.
Other than that, check the ECU connector and the voltage powering the ECU.
www.mytwinturbo.com
Nissan Data Voice on YouTube
Watch an ECZA meet caravan!
