TwinTurbo.NET: Nissan 300ZX forum - Did you adjust the clutch travel?
Subject Did you adjust the clutch travel?
Posted by Chickan on April 26, 2012 at 6:18 PM
  This message has been viewed 121 times.
In Reply To Clutch gone? posted by HK'S Z on April 26, 2012 at 10:35 AM
Message There is an adjustment screw on the clutch pedal. Loosen it and then you can twist the rod. Adjust it so the car start moving (1st gear) when the pedal is ~1" off of the ground. I can't remember which way tightens it, so try one way, then the other. You do not need to re-tighten the nut until you find the good spot and want to lock it down. Do tighten the nut eventually, or else it could work its way loose!
