TwinTurbo.NET: Nissan 300ZX forum - Skipped tooth worst case. Also my timing light would get two
Subject Skipped tooth worst case. Also my timing light would get two
Posted by treese88 on April 26, 2012 at 9:29 AM
  This message has been viewed 213 times.
In Reply To My CAS is off to one side as well. posted by rojoloco (VA Beach) on April 26, 2012 at 06:59 AM
Message Readings based on how I place the clip on the wire. Try both the put loop and 1st coil wire and if you can get a reading that puts it in the center that is probably right.
You can also put it in the center and see how it runs, just don't go boosting around until you verify it's correct.
'91 TT
