TwinTurbo.NET: Nissan 300ZX forum - I did that, but the whirring under even a relatively light
evan_aggie(ATX)
on April 25, 2012 at 7:34 AM
Yes, and I would probably do the same thing
posted by Stadsport (PHX)
on April 25, 2012 at 12:17 AM
load is indicating to me the pump is using the high output more than the low. I've seen multiple folks say the pump would last longer if it had the medium input active to a TT FPC.
What do you think? Is that bogus?
3 speed fuel pump wiring...
evan_aggie(ATX)
22:40:57 04/24/12
that new wire was supposed to go from the ECU to the FPC (n/m)
evan_aggie(ATX)
22:44:02 04/24/12
The connector is on the back side of the fuse block.
Woody75 (Denver)
23:09:13 04/24/12
Which front side connector? I was not able to identify
evan_aggie(ATX)
23:25:00 04/24/12
It's been awhile since I did.
Woody75 (Denver)
00:02:19 04/25/12
That blue plug must be behind all of that junk. Can't I
evan_aggie(ATX)
07:38:57 04/25/12
Yes, you could go direct end to end.
Woody75 (Denver)
09:13:00 04/25/12
You think a 15A fuse is appropriate for that wire? (n/m)
evan_aggie(ATX)
11:03:45 04/25/12
I would have to look over the wiring chart, but
Woody75 (Denver)
13:38:17 04/25/12
I thought that was the whole purpose of the purple wire
evan_aggie(ATX)
13:43:45 04/25/12
The connection is just part of the fuse box assembly.
Woody75 (Denver)
14:47:38 04/25/12
Stadsport (PHX)
00:17:11 04/25/12
I did that, but the whirring under even a relatively light -
evan_aggie(ATX)
07:34:06 04/25/12
I don't think it's bogus but...
Stadsport (PHX)
17:01:40 04/25/12
