TwinTurbo.NET: Nissan 300ZX forum - Yes, and I would probably do the same thing
Stadsport (PHX)
on April 25, 2012 at 12:17 AM
3 speed fuel pump wiring...
posted by evan_aggie(ATX)
on April 24, 2012 at 10:40 PM
But in every swap I've worked on I just chip the NA ECU and install a TT fuel pump.
evan_aggie(ATX)
22:40:57 04/24/12
that new wire was supposed to go from the ECU to the FPC (n/m)
evan_aggie(ATX)
22:44:02 04/24/12
The connector is on the back side of the fuse block.
Woody75 (Denver)
23:09:13 04/24/12
Which front side connector? I was not able to identify
evan_aggie(ATX)
23:25:00 04/24/12
It's been awhile since I did.
Woody75 (Denver)
00:02:19 04/25/12
That blue plug must be behind all of that junk. Can't I
evan_aggie(ATX)
07:38:57 04/25/12
Yes, you could go direct end to end.
Woody75 (Denver)
09:13:00 04/25/12
You think a 15A fuse is appropriate for that wire? (n/m)
evan_aggie(ATX)
11:03:45 04/25/12
I would have to look over the wiring chart, but
Woody75 (Denver)
13:38:17 04/25/12
I thought that was the whole purpose of the purple wire
evan_aggie(ATX)
13:43:45 04/25/12
The connection is just part of the fuse box assembly.
Woody75 (Denver)
14:47:38 04/25/12
Yes, and I would probably do the same thing -
Stadsport (PHX)
00:17:11 04/25/12
I did that, but the whirring under even a relatively light
evan_aggie(ATX)
07:34:06 04/25/12
I don't think it's bogus but...
Stadsport (PHX)
17:01:40 04/25/12
