TwinTurbo.NET: Nissan 300ZX forum - Yep those are all good (they've been swapped). Stock
treese88
on April 24, 2012 at 8:29 PM
Sounds like an issue with timing. Are your MAF(s), TPS and
posted by Gordo 93TT Daytona
on April 24, 2012 at 07:52 PM
timing maps are in use, but I'll fire up Nistune this weekend in case anything is funky. Crazier things have happened, that's for sure. Thanks for the reply.
'91 TT
RPM dip when tapping throttle - only when cold
treese88
12:26:32 04/24/12
I have this same issue.
Draker (Eugene, OR)
12:37:21 04/24/12
When I talked to SZ months ago their guess for a different
treese88
15:25:40 04/24/12
You should check your fuel pressure,
MeatMan - 604Z.ca -
13:10:02 04/24/12
Thats what I thought at first..so I first pressure tested
treese88
15:17:55 04/24/12
what do you consider "significantly"? (n/m)
fuzzymonkey
14:22:07 04/24/12
Significantly is probably not the right word. If I'm idling
treese88
15:21:43 04/24/12
Gordo 93TT Daytona
19:52:08 04/24/12
Yep those are all good (they've been swapped). Stock -
treese88
20:29:19 04/24/12
I would take another look at the timing as well.
Draker (Eugene, OR)
00:27:43 04/25/12
My cas is 15 dead center :/ darn
treese88
07:40:02 04/25/12
Good luck. Keep us posted. (n/m)
Draker (Eugene, OR)
17:37:10 04/25/12
My CAS is off to one side as well.
rojoloco (VA Beach)
06:59:31 04/26/12
Skipped tooth worst case. Also my timing light would get two
treese88
09:29:17 04/26/12
When it is in the center, it runs for crap.
rojoloco (VA Beach)
10:46:35 04/26/12
On all TT i have owned the cas has never been centered
toykoz32
22:40:18 04/26/12
It was pretty muh dead center on my last motor.
rojoloco (VA Beach)
05:21:00 04/27/12
I had the same problem . . once i sync'd the throttle
toykoz32
01:07:37 04/25/12
I remember seeing a write-up somewhere IIRC.
rojoloco (VA Beach)
07:00:10 04/26/12
Best one I found was related to syncing z1 tb's. Aafter I
treese88
09:25:27 04/26/12
Did this yesterday. Good recommendation and helped a little
treese88
09:22:48 04/26/12
Did you also get the slack out of the accelerator cable? (n/m)
toykoz32
16:10:50 04/28/12
It was already properly adjusted, forgot to mention.
treese88
19:35:51 04/28/12
I have the same problem.
rojoloco (VA Beach)
07:04:18 04/26/12
Very similar except I'm rich...and not moneywise!
treese88
09:35:57 04/26/12
I can try it out since it is easy.
rojoloco (VA Beach)
10:49:02 04/26/12
After adjusting the TB'S and then the TPS the dip appears to
treese88
13:47:42 04/30/12
