TwinTurbo.NET: Nissan 300ZX forum - Jack up the rear, and apply the parking brake.
Subject Jack up the rear, and apply the parking brake.
Posted by Gordo 93TT Daytona on April 24, 2012 at 8:12 PM
  This message has been viewed 197 times.
In Reply To rear end slack/clunk/play? posted by timmaz on April 21, 2012 at 10:03 PM
Message your rear wheels are now fixed. Turn your prop shaft with one hand while you hang onto one of the drive axles. Then repeat on the other side drive axle. You should be able to see the freeplay if it is in either the diff or the drive axles. At 103K miles, you probably have both backlash in your ring and pinion, and freeplay in the two sets of drive axle joints. The drive axles are both easier and cheap to fix first. Our diffs are pretty stout and most guys do not have problems with them.
_________________________________________________
