TwinTurbo.NET: Nissan 300ZX forum - Brake and Clutch booster vacuum test question
Subject Brake and Clutch booster vacuum test question
Posted by treese88 on April 24, 2012 at 5:34 PM
  This message has been viewed 454 times.
Message Trying to solve some issues on my car (as can be noticed by the other tech post below this). Search results weren't specific enough for my liking.
I went ahead and used a mityvac handpump to test both the clutch and brake boosters today.
Brake booster: Can only get to 7.5hg with a lot of pumping. Probably drops from 5.0hg to 0 within a minute. I feel like it is suppose to hold a lot longer and might be part of my Z's issues. I can nearly stall the car by pumping the brakes in idle, but I hadn't revisited the issue because I was told this is normal. Not sure if this is related.
Side note - when I reverse down my driveway (steep hill after garage) my brake pedal will clunk once I transition to the hill (only happens when going down the hill). Makes me think I may need to bleed the brakes more. If I have to replace the booster this will happen anyway.
Clutch booster: Can build vacuum with just a few pumps. The vacuum drops very slowly. Would probably take 10 minutes to go from 5-0. Maybe more, maybe less, complete guesstimate. Much less than brake booster.
Brake booster was the first thing I ever replaced on my car after getting it running (years ago). I bought one used off eBay to replace the old one which held no vacuum causing major issues. My brakes seem to work fine. I think from reading the vacuum shouldn't drop period, but I wanted to check. Re-replacing the brake booster is one of the last things I want to do at the moment. It is a total pain in the ass!
Thanks for replies!
'91 TT
