TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: Re: Re: Check the fuses by the battray...
Subject Re: Re: Re: Re: Re: Check the fuses by the battray...
Posted by Da Flash on April 22, 2012 at 8:43 AM
  This message has been viewed 240 times.
In Reply To Re: Re: Re: Re: Check the fuses by the battray... posted by PULSAR GTR on April 21, 2012 at 09:01 PM
Message Well, after I fix my "spraying gas leak" that seems to be coming from underneath the fuel pressure regulator, I will test for spark and power at the injectors.
On a side note, I've discovered that the engine won't even turn unless I turn the key on/off a couple of times, then it will turn over but won't start.
Thanks for all the suggestions!!!
