TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: Re: Check the fuses by the battray...
Subject Re: Re: Re: Re: Check the fuses by the battray...
Posted by PULSAR GTR on April 21, 2012 at 9:01 PM
  This message has been viewed 200 times.
In Reply To Re: Re: Re: Check the fuses by the battray... posted by Da Flash on April 21, 2012 at 08:30 PM
Message if the car isn't starting, it is either no spark or no fuel, remove one coil and isntall a spark plug in it and ground the spark plug to the engine, have some one crank the engine, check for a spark on the plug, keep your hands away as you dont want to get zapped.
if you get spark, check if you are getting fuel, disconnect your fuel line and point it to a bottle, crank the engine, as you are cranking, you should have continuous fuel, if you don't the CAS might be defective, if you do have continous fuel, check if the injectors got power, fyi, the injectors will have constant 12vs regardless if the ignition is on or off, it is the ground that pulses, so get a tiny low power 12v light bult and hook it up accross the two pins on the injector plug and have some one crank the engine, you should see the light bulb flash.
Cheers,
Rafi
