TwinTurbo.NET: Nissan 300ZX forum - Cap/pinch the vacuum line to the egr valve.
soulpwr
on April 19, 2012 at 4:11 PM
ZXoltan - Yes I have to have it since I am in Cali
posted by HK'S Z
on April 18, 2012 at 04:45 PM
If the problem goes away it's the valve. Another way to test it is to hook up a vacuum pump to it at idle and pump it. If the car shuts off the ports are clear, if it runs rough the ports are blocked.
Out of ideas...air leak
HK'S Z
13:52:05 04/18/12
You still have the EGR installed?
ZXoltan
15:20:42 04/18/12
I'd look there first also. (n/m)
Gordo 93TT Daytona
15:41:18 04/18/12
HK'S Z
16:45:09 04/18/12
Cap/pinch the vacuum line to the egr valve. -
soulpwr
16:11:40 04/19/12
If I'm not mistaken the valve can leak for other
ZXoltan
06:22:39 04/20/12
Soulpwr/ZXoltan - Thank you, I will check it out this
HK'S Z
09:29:57 04/20/12
Spark plugs?
gnozahs
20:45:35 04/18/12
Gnozahs - Spark plugs have about 50 miles on em.
HK'S Z
09:52:21 04/19/12
