TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: Front brake shaking solution?
Subject Re: Re: Re: Front brake shaking solution?
Posted by 300ZMang on April 19, 2012 at 2:18 PM
  This message has been viewed 217 times.
In Reply To Re: Re: Front brake shaking solution? posted by AsaHerring on April 19, 2012 at 01:20 PM
Message I'm assuming your steering wheel shakes/vibrates when you brake?
There is also a universal joint in the steering that also goes bad over time and loses it's strengh/functionability.
I'd say you're a master at warping rotors, there is a process for bedding brake pads properly when you get new pads/rotors, so this doesn't happen.
I'd first suggest new rotors and tension rod bushings. Get the new ES 3 piece bushings and install them yourself, they are like $30 I think, make a world of a difference.
