TwinTurbo.NET: Nissan 300ZX forum - ECU Pin 16 high voltage
Subject ECU Pin 16 high voltage
Posted by MoGaffar on April 19, 2012 at 10:35 AM
  This message has been viewed 505 times.
Message Hey guys,
I recently had some issues with my maf readings. I took a look at the wiring harness and it look like 2 wires had some broken strands. Stupidly i forgot to un-hook the battery and i started cutting/soldering the wire back up. Upon finishing i tried starting my car and it would just crank, no fire.
I check over all fuses, relays all seem to be perfectly fine. I started going through the FSM main power supply routing on page 104 of the EF and EC section. It said to check power on the ECCS relay, continuity to and from the ecu, and power on pin 16.
On the ECU pin 16, instead of the FSM stated 0.8volts to 1volt. My pin 16 shows 12 volts ( battery voltage). Now I did these tests with the ECU disconnected.
If anyone, has an idea please help me out as I want to drive my Z again.
___________________________________________________________
"She's always wet and hot and purrs when I slide inside of her. She screams when I put my foot down and isn't too hard to control. She is usually straight but she slides her rear out when I ask her too. Always gives me a boost. Stays with me and leaves the other guys behind. She is even more fun when her top is off...so free. Sometimes a friend will join in, male or female, and we both enjoy her. Plus she is a non smoker...what more can you ask for?" ***taken from ScottyFender***
