TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: Mystery that neither a shop nor I can figure out.
mkhoid
on April 18, 2012 at 4:53 PM
posted by Dawei
on April 17, 2012 at 10:34 PM
Well if you're gonna pull the plenum to confirm. you can always plug the injector connect back and glance at the lower manifold where the valves are, then have the engine turn "on" not "start" to see if fuel comes out of the cylinder.
Dawei
21:26:41 04/17/12
nzryan
22:06:16 04/17/12
Dawei
22:34:49 04/17/12
Re: Re: Re: Mystery that neither a shop nor I can figure out. -
mkhoid
16:53:41 04/18/12
Pinched injector O-ring
Draker (Eugene, OR)
22:06:19 04/17/12
Re: Pinched injector O-ring
Dawei
22:33:00 04/17/12
mkhoid
22:10:29 04/17/12
Dawei
22:31:44 04/17/12
mkhoid
23:24:10 04/17/12
Re: Re: Re: Re: Mystery that neither a shop nor I can figure out.
Dawei
00:02:12 04/18/12
Do the fuel pressure test and verify! Don't over look it.
Draker (Eugene, OR)
10:21:57 04/18/12
Re: Do the fuel pressure test and verify! Don't over look it.
Dawei
17:22:01 04/18/12
I wonder if there's a possibility you were sent the wrong
Evan_Wright (Ca)
00:42:05 04/18/12
Re: I wonder if there's a possibility you were sent the wrong
Dawei
00:50:29 04/18/12
Dawei
01:08:07 04/18/12
Re: Re: I wonder if there's a possibility you were sent the wrong
lurker_nz
02:16:59 04/18/12
Re: Re: Re: I wonder if there's a possibility you were sent the wrong
Dawei
02:31:38 04/18/12
Ive did the dremel method and it works amazing.
JoshE300zxTT
09:00:18 04/18/12
2nd (n/m)
OverZealous (CT)
17:24:49 04/19/12
Dawei
21:22:01 04/18/12
You need to have them flow tested. Pull the plenum and
Evan_Wright (Ca)
22:50:09 04/18/12
