TwinTurbo.NET: Nissan 300ZX forum - Do the fuel pressure test and verify! Don't over look it.
Draker (Eugene, OR)
on April 18, 2012 at 10:21 AM
Re: Re: Mystery that neither a shop nor I can figure out.
posted by Dawei
on April 17, 2012 at 10:31 PM
You can install an injector 5 times in a row and still pinch an oring. If the orings are not lubed up before installing you are asking for a hydrolock. Do the leak down test and report back.
Dawei
21:26:41 04/17/12
nzryan
22:06:16 04/17/12
Dawei
22:34:49 04/17/12
Re: Re: Re: Mystery that neither a shop nor I can figure out.
mkhoid
16:53:41 04/18/12
Pinched injector O-ring
Draker (Eugene, OR)
22:06:19 04/17/12
Re: Pinched injector O-ring
Dawei
22:33:00 04/17/12
mkhoid
22:10:29 04/17/12
Dawei
22:31:44 04/17/12
mkhoid
23:24:10 04/17/12
Re: Re: Re: Re: Mystery that neither a shop nor I can figure out.
Dawei
00:02:12 04/18/12
Do the fuel pressure test and verify! Don't over look it. -
Draker (Eugene, OR)
10:21:57 04/18/12
Re: Do the fuel pressure test and verify! Don't over look it.
Dawei
17:22:01 04/18/12
I wonder if there's a possibility you were sent the wrong
Evan_Wright (Ca)
00:42:05 04/18/12
Re: I wonder if there's a possibility you were sent the wrong
Dawei
00:50:29 04/18/12
Dawei
01:08:07 04/18/12
Re: Re: I wonder if there's a possibility you were sent the wrong
lurker_nz
02:16:59 04/18/12
Re: Re: Re: I wonder if there's a possibility you were sent the wrong
Dawei
02:31:38 04/18/12
Ive did the dremel method and it works amazing.
JoshE300zxTT
09:00:18 04/18/12
2nd (n/m)
OverZealous (CT)
17:24:49 04/19/12
Dawei
21:22:01 04/18/12
You need to have them flow tested. Pull the plenum and
Evan_Wright (Ca)
22:50:09 04/18/12
