TwinTurbo.NET: Nissan 300ZX forum - Wheel and brake advice needed
Subject Wheel and brake advice needed
Posted by Mikester(Seattle) on December 05, 2011 at 4:23 AM
  This message has been viewed 139 times.
Message I am at the point where my tires need replaced and my brakes are getting thin. I don't track my car, and probably never will. It's a stock height 94 twin turbo presently with stock wheels, and no plans of lowering it.
I was browsing the brake/rotor options on Z1's website, and I discovered the 13" front rotor upgrade package:
[ http://www.z1motorsports.com/product_info.php?cPath=6_9&products_id=2485 ]
Realizing that these won't fit under stock wheels, I then decided to shop for larger, wider wheels. Not wanting to break the bank, I found some wheels I like: The Rota P45R/F.
[ http://www.rotawheels.com/wheels.asp?wheelid=31 ]
and
[ http://www.rotawheels.com/wheels.asp?wheelid=30 ]
My questions are:
Is this brake kit a good choice for a non-track vehicle that is due for a brake job?
Would you add a brake master cylinder brace as well to prevent firewall flexing?
What offset would be needed for 275/35/18 rears and 245/40/18 fronts, assuming I went with 18x9.5 and 18x8.5 wheels?
Is the HICAS steering knuckle going to be an issue with these wheels?
I don't want the tires to rub, and I realize some clearance is needed for caliper relocation on the brake kit above. Too much offset and the brakes will be close to the spokes and require a wheel spacer. Too little and the wheels could stick out too far. I'm thinking 40-50mm offset in the rear and roughly 35 in the front.
Thanks!
