TwinTurbo.NET: Nissan 300ZX forum - did you check continuity between the signal wire and ground?
Subject did you check continuity between the signal wire and ground?
Posted by aliaZ on November 15, 2011 at 10:48 PM
  This message has been viewed 164 times.
In Reply To Still Code 34!! Wtf!!! posted by 91FairladyTT on November 15, 2011 at 06:50 PM
Message There should be no continuity between signal and ground...if there is you have an EFI harness issue. I had this happen on my 240sx...there was even a TSB on it. The problem was solved by cutting the sheilding on the signal wire, which had apparently grounded out the signal wire due to a fault in the harness.
