TwinTurbo.NET: Nissan 300ZX forum - Still Code 34!! Wtf!!!
Subject Still Code 34!! Wtf!!!
Posted by 91FairladyTT on November 15, 2011 at 6:50 PM
  This message has been viewed 160 times.
Message So I still get Code 34 after I did the knock sensor relocation. Installed the new sensor new sub harness and cleared codes got 55 strted and let car idle for 20 secs checked ecu and code 34!! Wtf? I even swapped the other nearby plug that gets mixxed with the knock sensor and cleared codes idled for 20 sec and code 34. I removed the ecu and harness I'm pretty sure I found the same black wire with brown stripe that's on the knock sensor plug and I did a continuity check and it was good so no broken wire as long as that was the right wire... So if all is good then what is causeing me to have this stupid code 34?
Thank you.
