TwinTurbo.NET: Nissan 300ZX forum - Yup. I put the bushing over the trans shaft before hand.
Subject Yup. I put the bushing over the trans shaft before hand.
Posted by evan_aggie(ATX) on November 15, 2011 at 2:37 PM
  This message has been viewed 167 times.
In Reply To Did you measure? Do you know for sure that the posted by zellamay on November 15, 2011 at 11:13 AM
Message Just to check that it did indeed fit.
How else can the clutch be aligned? I used the tool, installed the clutch, pressure plate, bolted everything down... it should be fine.
I guess you guys are probably right...I just need to try again...go at it from a few different angles (that's what she said?) and it'll magically slide right in.
I was getting really pissed last night and sore trying to lift that bad boy off the trans jack and push it in....
