TwinTurbo.NET: Nissan 300ZX forum - AEM Tru Boost Install/Settings
Subject AEM Tru Boost Install/Settings
Posted by Blurr on November 14, 2011 at 5:29 PM
  This message has been viewed 1980 times.
Message Hi TT.net,
My name is Dave, and I been a long time reader/browser of TT. Really haven't posted here but wanted to get some advice from you guys running this boost controller.
I aqquired this boost controller from a friend who had it lying around. My Greddy Profec B Spec was not working correctly, so I installed this unit until I can get my hands on a Blitz.
Before installing the unit, because of the faulty unit, I was running at 5-6 psi of boost. After I installed this, Im at a steady 13.5 at WOT, and Im getting a steady -21 on my bost contoller at idle.
Is this max I can run on stock internals? The only mods my motor has are 555 size injectors, SAFC II, and JWT POP charger.
on stock turbos, the max I can run is 14 psi correct? There is a spring setting on this boost controller I have set at 7, can I set this higher or lower to run higher boost safely?
What are some of you guys settings for the unit?
I would like to achive 15 psi respectively.
Heres how I mounted it for now, until I can get a steering wheel column gauge mount from ionic dynamics. Does anyone know where I could get a steering wheel column gauge pod other than ionic?
Heres the one from Ionic...
