TwinTurbo.NET: Nissan 300ZX forum - dazed and confused... 1 and 5 still arent firing...
Subject dazed and confused... 1 and 5 still arent firing...
Posted by GitNMyBelly on November 13, 2011 at 5:38 PM
  This message has been viewed 139 times.
Message ok so i had to change my #3 injector and while i was in there i decided to change my spark plugs. however after the change, now my 1 and 5 are not firing. when i pull the coil pack connector there is no change in how the car runs.
ok i have done...
i pulled the cas and got older injectors and feel the injectors tick when i turn the cas. 1 and 5 are ticking...
i pulled the coil packs and put a plug on the coils and turned the cas and it sparks....
so now what do i check. i am totally confused. after pulling the one injector... am i suppose to repressurize the rail? if so how do i do this? i primed it, by turning the key w/o cranking.
please help... thanx
