TwinTurbo.NET: Nissan 300ZX forum - alright no need to bleed then
Subject alright no need to bleed then
Posted by Khronik on November 11, 2011 at 4:51 PM
  This message has been viewed 99 times.
In Reply To How old is your clutch? posted by Poppe on November 11, 2011 at 12:11 PM
Message youre correct I did not adjust the rod and I am pretty sure the clutch is failing but will see after I finish this
on the 3rd switch - where should the threads be in relation to the welded nut? does it need to be adjusted after the rod, so that the prong is fully depressed when the pedal is to the floor?
