TwinTurbo.NET: Nissan 300ZX forum - How old is your clutch?
Subject How old is your clutch?
Posted by Poppe on November 11, 2011 at 12:11 PM
  This message has been viewed 112 times.
In Reply To Clutch Adjustment Help posted by Khronik on November 10, 2011 at 06:01 PM
Message Is it possibly worn out? Floor the car in 5th gear - if it slips and you have more than like 30k on your clutch, I'm gonna guess your clutch itself is failing.
You do not need to bleed the clutch after adjusting the pedal, unless you sucked in air somehow.
If reads like you backed out the switches, but then didn't adjust the pedal at all. If this is true, you should adjust the pedal as well, so that the switch prongs should close all the way - this is why you lost cruise control - it thinks the clutch is depressed.
The 3rd switch? Meaning the one that gets triggered when the clutch is all the way in? That's for the starter relay - it stops you from starting the car without the clutch fully engaged.
