TwinTurbo.NET: Nissan 300ZX forum - Re: Fuel pump or not fuel pump?
Subject Re: Fuel pump or not fuel pump?
Posted by Stadsport (PHX) on November 10, 2011 at 3:09 PM
  This message has been viewed 141 times.
In Reply To Fuel pump or not fuel pump? posted by dvice on November 10, 2011 at 10:53 AM
Message 1. Have you run codes? It's possible it could be the fuel pump, but there's plenty to check before you drop $300 on what is basically a guess. I would suspect something like the CAS connector.
2. You can get a TT pump, it will just be a little louder. Keep in mind, though, that if you get a US TT Pump, it will come with a 2-seater sock installed, and you'll have to swap the sock over from your old fuel pump.
3. You can get to it from the trunk, just remove the floor boards in the rear.
