TwinTurbo.NET: Nissan 300ZX forum - Re: cause it's probably your injector
Subject Re: cause it's probably your injector
Posted by Krazyd27 on November 08, 2011 at 3:10 PM
  This message has been viewed 199 times.
In Reply To cause it's probably your injector posted by zgene4 on November 08, 2011 at 02:01 PM
Message If changing your coil pack doesn't change the results, do an ohm check on your injectors. If they are still within spec, I reccomend you do a compression test. I had a similar problem a while back and when I tore the block apart for further inspection, I had hole on my piston and was losing compression. Hope you fix your problem and let us know
