TwinTurbo.NET: Nissan 300ZX forum - Be sure to get only 3/4" to 1 3/4" hose clamps because
Subject Be sure to get only 3/4" to 1 3/4" hose clamps because
Posted by craigz96tt on November 05, 2011 at 6:27 PM
  This message has been viewed 97 times.
In Reply To Coolant leak after t belt install posted by pilikua on November 04, 2011 at 10:15 PM
Message anything larger than that you will feel like you tightened the clamp fully but it will run out of slots on the clamp and be just loose enough to cause leaks. I speak from experience so please check the clamps I bet they are at the last slot and not sealing. Also it doesn't hurt to use two on each connection
