TwinTurbo.NET: Nissan 300ZX forum - Same here , run a high tension wire from coil pack 1
Subject Same here , run a high tension wire from coil pack 1
Posted by Xteam300TT (South Tx ) on November 05, 2011 at 5:41 PM
  This message has been viewed 334 times.
In Reply To Does it matter which method I use to check timing. posted by z32z on November 04, 2011 at 07:34 PM
Message to the spark plug . make sure the engine is FULLY warmed up . make sure you shoot the timing from about 10 to 11 degrees , not straight down . And see what the ecu is reading in comparison to the base timing . Also if you are still getting crazy #'s flip your timing light pickup 180 degrees and see if it changes . Always check it with a second timing light before you dive into the timing belt ..... dont ask me how I know :)
