TwinTurbo.NET: Nissan 300ZX forum - No spark issues. firing on 3 cylinders
Subject No spark issues. firing on 3 cylinders
Posted by akdawgg99 on November 05, 2011 at 11:49 AM
  This message has been viewed 385 times.
Message First off
-Brand new EFI harness (from concept z)
-Old injectors
-Old coil packs
Cylinder 3, 5 and 4 are not firing. I determined this by pulling the connectors to the coil packs and the idle did not change.
Injectors are working as far as I can tell (I listened to them with a screw driver and there is fuel on the plugs). The plugs that are firing are COVERED in black soot.
I tried swapping coil packs, but the problem doesn't go with the pack, it stays at the cylinder.
Does this mean bad wiring?? Its a brand new EFI harness
(bought over the summer, just got the engine running a few weeks ago).
Could it be the ECU? I know my CAS is good as well as my PTU.
