TwinTurbo.NET: Nissan 300ZX forum - Preferably, yes
Subject Preferably, yes
Posted by cherryz on November 05, 2011 at 11:45 AM
  This message has been viewed 107 times.
In Reply To Coilover question posted by WhiTTe Z on November 05, 2011 at 10:52 AM
Message Our suspension is not adjustable, so you need to change out the upper camber arms with adjustable ones. For the front, you can use the 300degree camber shim kit for a cheaper solution.
I went with the PowerTrix setup on everything (including tension rod) except for the Front Upper Camber Arm where I used the 300degree shim kit.
