TwinTurbo.NET: Nissan 300ZX forum - No power from Cylinder 2 - injector & plug ok (?)
Subject No power from Cylinder 2 - injector & plug ok (?)
Posted by cherryz on November 05, 2011 at 11:32 AM
  This message has been viewed 105 times.
Message Lost power from cylinder 2, verified by performing a balance test.
Here's what I've done:
1. Checked injector impedance = 11 ohms
2. Swapped plug with Cyl 1 - no change
3. Swapped coil with Cyl 1 - no change
4. Used stethoscope on injector - can hear clicking (same sound as compared to other injectors)
This injector was replaced back in April (-3,500 miles) with an untested, but working used injector. I have a set of tested, cleaned injectors from Bernie that I can drop in w/o a problem, but since the injector is showing 11 ohms, I'm wondering if there is another problem here.
Also a factor - I performed the switched 12V mod back in June (-2000 miles) because I was tired of injectors failing. (Injector #5 is the only original one.) I'm fairly confident in my mod, since the injector is clicking.
I have never done a compression test on this engine.
Since everything seems correct, what else should I check out?
