TwinTurbo.NET: Nissan 300ZX forum - Unorthodox Racing UP is what I have - no issues,
Subject Unorthodox Racing UP is what I have - no issues,
Posted by jzack on November 04, 2011 at 6:37 PM
  This message has been viewed 107 times.
In Reply To any other suggestions? posted by Khronik on November 04, 2011 at 05:08 PM
Message many on here advise staying clear of AMS parts (run a search)....
Also forgot to mention above - some also do an ECU grade, not sure how much this really helps and NA? Atho is can allow the elimination of the AIV system for a bit of a weight reduction and some under car simplicity. For the O2s, run the ECU test on those and verify all is good, if so - no need to replace.
Other items can make sense when doing mtce in that area - not sure I'd spend a lot of time or $$$ otherwise. Other mtce depends on what needs to be pulled apart? If valve covers are leaking badly -- maybe worth pulling the plenum?
Fuel hoses are also a good thing to worry about if old. In colder weather on these cars, clamps can't be tightened more and you may smell some gas, another thing to fix.
Everything you are asking has been posted about this car over the years , just run forum searches or use Google site search...
OK?
