TwinTurbo.NET: Nissan 300ZX forum - 34 is for knock circuit failure, not knock being detected (n/m)
Dane (Houston)
on November 02, 2011 at 2:49 PM
Sure it kills your power and boost, but it's saves your
posted by Bo (Houston)
on October 30, 2011 at 06:54 PM
Battling code 34...still
JoshE300zxTT
15:25:49 10/29/11
Did you already measure through the harness to the ECU?
Draker (Eugene, OR)
02:03:45 10/30/11
yes i just measured threw the ECU harness and got some
JoshE300zxTT
07:36:43 10/30/11
It's a straight wire I am pretty sure?
Draker (Eugene, OR)
12:07:32 10/30/11
i will have to double check because the harnees that i
JoshE300zxTT
17:12:18 10/30/11
here is a picture of the connector i measured the resistance
JoshE300zxTT
17:46:43 10/30/11
This is the right one.
Draker (Eugene, OR)
18:38:14 10/30/11
thats 513 ohms. consider that bad lol
Dane (Houston)
15:02:35 11/02/11
Re: Battling code 34...still
craigz96tt
10:23:53 10/30/11
Re: Re: Battling code 34...still
Bo (Houston)
14:14:45 10/30/11
im pretty sure it does retard the timing any time the code
JoshE300zxTT
17:13:47 10/30/11
I don't have safety boost w my jwt ecu runs strong (n/m)
craigz96tt
10:31:47 10/31/11
so you keep getting an intermitten code 34?
JoshE300zxTT
07:27:01 11/02/11
Bo (Houston)
18:54:40 10/30/11
yea im 100% sure, there is no banging or pinging in the
JoshE300zxTT
07:25:36 11/02/11
34 is for knock circuit failure, not knock being detected (n/m) -
Dane (Houston)
14:49:25 11/02/11
AsaHerring
10:42:03 11/03/11
i have pretty much did everything you have done!
JoshE300zxTT
15:25:49 11/03/11
A 100K ohm resistor going from the knock sensor ECU pin then
TTNIckdizzle
11:34:00 11/04/11
