TwinTurbo.NET: Nissan 300ZX forum - The most obvious choice is to clean/check the CTS
Subject The most obvious choice is to clean/check the CTS
Posted by CoHPhasor on November 02, 2011 at 5:23 AM
  This message has been viewed 164 times.
In Reply To Injector question posted by Figifister on October 28, 2011 at 10:47 PM
Message Those are more than close enough to spec.
Run some fuel system cleaner as a double coverage.
If the CTS (Coolant Temp Sensor (2-wire)) on the coolant hardpipe has a corroded connector, or your coolant is low it will tell your ECU the engine is colder than it is.
(The Z32 ECU compensates for cold weather by enriching the fuel map)
