TwinTurbo.NET: Nissan 300ZX forum - Fuel Pressure Regulator
Subject Fuel Pressure Regulator
Posted by Roundabout136 on October 31, 2011 at 5:56 PM
  This message has been viewed 151 times.
Message If this part was to fail, could it cause a situation where the car would start up normally after priming the fuel system, but then immediately stall?
I can keep the car running when the throttle is blipped/pressed but once I release it stalls.
Code 55, no vac leaks.
Fuel pressure primes to 44, spikes when cranking to around 55, once car stalls fuel pressure quickly dies out. Pretty sure it's going straight back into the tank.
Fuel pump was recently replaced with a good unit from Bernie, thinking that was the problem...
