TwinTurbo.NET: Nissan 300ZX forum - Plug corrosion...
Subject Plug corrosion...
Posted by carwash on October 31, 2011 at 10:05 AM
  This message has been viewed 159 times.
Message So I'm tearing down the top of my motor to install all new injectors, injector pigtails, and valve cover gaskets. My injector plugs were very corroded, as expected. No big deal because I'm replacing those. But, on the rest of the plugs, like the detonation sensor plug, O2 sensor, and the variable valve timing connector. These all have the same type of connectors as the injectors, and all are very very corroded. Is there something I can clean these will with that I can trust will take care of it, or should they be replaced, etc?
Also, the nice blade type plug holders on the back of the motor aren't doing much since the tabs on the plugs are all broken off. Is there a fix for this, do i replace these plugs? Any advice is much appreciated.
