TwinTurbo.NET: Nissan 300ZX forum - It's possible that your reverse check assembly has failed
Subject It's possible that your reverse check assembly has failed
Posted by SeanK (StL) on October 31, 2011 at 8:33 AM
  This message has been viewed 1802 times.
In Reply To No reverse in 5spd! please help ! posted by lackodeniro on October 30, 2011 at 09:32 PM
Message Not a big problem and possible to remove and replace with the transmission in the car. Should be about $30. part # 32180-33P03 can be found on "328 Transmission Shiftcontrol" parts sheet.
It's located on the drivers side of the transmission as seen here. Held in by 1x 10mm bolt.
Mine was stuck in the transmission and required a drop to get enough force on it to remove. Others have had better luck removing it with the transmission in place. You should be able to pull it and verify that both ears of the spring are intact.
New left, old/broken right
If this part is ok then you might need to dig into the tranny case to figure out what's the problem.
Good luck.
