TwinTurbo.NET: Nissan 300ZX forum - Battling code 34...still
Subject Battling code 34...still
Posted by JoshE300zxTT on October 29, 2011 at 3:25 PM
  This message has been viewed 186 times.
Message I have been stuck in safety boost mode for ever and i know this is a very common problem. I did find that my harness was broken. So i cut the plug off of my old harness and soldered it to my current harness. I went out and drove it and i am still getting the code. So i hooked a voltmeter up to the harness going to the sensor and started taping the side of the block. The volts were going up like they were suppose too.
Im stuck on where to go next? The only other option i have is something i found in the tech section
If the ECU is dropping into safety boost all the time with no obvious reason, this is a possible JWT approved fix method. Find the connector coming off the passenger wastegate solenoid. It's the black plug with two wires, a black and white wire on one side and black and green on the other. Get a short bit of extra wire & solder a paperclip to the end of it, cram it in the backside of the plug into the green wire's pin. Electrical tape this together. Ground the other end of the wire, essentially grounding the green wire. The bracket on the side of the plenum has a convenient spot for it.
Does this work?
Any suggestions. Thanks
Josh E.
