TwinTurbo.NET: Nissan 300ZX forum - Injector question
Subject Injector question
Posted by Figifister on October 28, 2011 at 10:47 PM
  This message has been viewed 257 times.
Message 1994 N/a 86k. I ohm tested the injectors and this is what I got. I purchased new injectors but the plan was to swap these into another Z after they were cleaned and flow tested.
Symtoms:
Erratic idle (fluctuates between 700 and 900rpm)
Fuel smell on cold starts
#2 was sticky
#3 is out of spec
Ohm numbers-
#1-11.2
#2-14.4
#3-15.9
#4-11.8
#5-11.1
#6-11.4
Can these be cleaned & Flow tested then swapped into a different Z? Or should I replace #3 and then flow test the rest? Would #3 and #4 being at that impedance have anything to do with the erratic idle? Thanks
