TwinTurbo.NET: Nissan 300ZX forum - Re: Battery drain issues revisted.
Subject Re: Battery drain issues revisted.
Posted by chicagozer on October 28, 2011 at 10:42 AM
  This message has been viewed 273 times.
In Reply To Battery drain issues revisted. posted by rojoloco (San Diego) on October 27, 2011 at 12:09 AM
Message If you do disconnect, one terminal is enough. Ground is preferred (by me at least).
Does your security lamp perma-flash 30 secs after you close the doors? This is the most common cause of a drain, and the most common cause of that is the alarm hood pin getting bent from dropping the hood to close it.
If you don't have that problem, you are going to have to pull fuses until you isolate it.
